Ok here is the deal. Im building a drag bike of sorts and I have a question regarding the clutch set up.
First off the engine is a Tec 8hp. Im running 6in wheels with I believe 8in rear tire. I have 2 different rear sprockets, 40 and 72 tooth. Now Im debating about running a centrifugal 12 tooth or a Tav 30 set up. What would the optimal set up be? I would like it to be fast(er) than my Arctic Cat mini's which are stock. I just dont want it to take forever to get out of the hole. If need be I could buy a different rear sprocket. Those of you that built drag bikes how did you set them up? Thanks
