I've recently decided to build a simple off road kart/buggy and I'm considering a change of plans. Since this will be my first ground-up project I want to make it simple yet effective. My original plan was to buy a new motor (420cc) and build a full suspension buggy but that seems a little complex to start with (mostly in regards to the challenges of setting up the steering geometry on a suspended build). I already have a built 212cc on hand that I'm tinkering with, so now my plan is to use that engine on a kart that only has rear suspension. The kart will be used in open fields and trails in the woods. Just want something to smooth out the bumps on unprepared surfaces (my Manco Dingo is fun but it bucks over every sizeable bump - not comfortable at speed). I know of a few karts that use this setup - notably the Spidercarts Tarantula/Scorpion (attached picture).
Would it be worth building or should I just bite the bullet and go full suspension? I can use springer spindles on the front to hopefully smooth out the front end a little bit.
