Ive got a 6.0hp brand new techumsen...i also have a mini-baja ungoverned 6.5 and a doodlebug i wanna put the new techumsen on the doodle bug is this good idea or should i put the techumsen on the mini-baja and then the6.5 lifan crap on the doodle??? and how do i put pics on here?????ut:
Somehow on my 6.5hp lifan motor we just messed with arm under the tank and its no longer governed and does bout 40 mph.... we never went into the engine to remove a platis gear.....
you don't need to remove the gear to disable it (it's a good idea to though). i just had it so the arm isn't hooked up to the throttle (don't even know if you could run it with a Mikuni).
