Waiting to hear back from OldMiniBikes, but figure maybe someone else has run into this and/or something to look out for.
Ordered the ARC_DJ-1305PH Hemi gasket set, in place of the stock fiber head gasket I received a steel version.
Okay maybe it's the higher compression version. Whoops! Problem. The holes in the new gasket for the alignment pins are in a different location. Original has the pins on either side of the push rods hole, the new one has one on the right side of the push rods hole, and the other is now up at the top left bolt hole. No problem moving the alignment pins, but the head is not relieved for the alignment pin's new location.
Wrong gasket? Right gasket, need to machine out the head to make it work? Toss out the one alignment pin?
