If it is leaking past the JET ITSELF slowly, it will run down by gravity to the lowest point (head of the screw) before it drips OFF from the carb... It may be your jet simply is not tight enough..
DO NOT OVER tighten it, because THEY WILL break or even twist out of shape.. it just needs to be SNUG.. But finger tight won't do it at all..
I also like to put the bowl bottom down on anything, use the blunt end of a screwdriver handle, and ever so gently drive it into the bowl, rite at the hole.. JUST a gentle tap, enough to mushroom the bottom of the bowl back out.. Only a millimeter or two, but enough to know you have pushed the bottom out some, so when you put the bowl back on... The bowl gasket is pinched tight and sealed good, millimeters before the bowl hits the bottom of the carb..
THAT WAY you not only know you're pinching the bowl gasket tight, but the gasket between the jet and bowl, ALSO has pressure on it BEFORE tightening it down at all..
If you guys are BOTH having this same problem, with a new rebuild kit, and are both certain it IS INFACT, the needle itself leaking...
I would venture to say, it is due to shit just being made cheaply anymore.. and the rubber O-ring and the screw are not the rite sizes to seal.. I/E hole in the O-ring is larger than it should be..
If it is all clean, and all assembled rite, IT CAN NOT leak...
If it is a BRAN NEW kit doing it to you, and it IS DOING THE IMPOSSIBLE... The only explanation would be piss pourly built O-ring..
take the adjustment needle out with spring and washer.. allow all the gas to drain so it' all dry, then dab some break fluid on the O-ring... Then put it back together and let it sit overnight before adding any gas..
and see what happens...
OR make a dime sized piece of inner tube, stab your adjustment needle through it.. then trim around the needle till the O-ring is the correct O/D size.. And make your own.. :laugh:
