My pull start is out of commission and while waiting on the new assembly to arrive, I tried starting the engine using a cordless drill and 11/16 socket. The engine started up, but the nut on the impeller loosened up and caused the impeller to fall off while the engine was running. I tried tightening the flywheel nut back down, but the rotation from the running engine seems to keep causing the nut to loosen, causing the impeller to keep falling off.
Am I missing something here, like a lock washer, snap ring, loctite to keep that nut from spinning off? How do I keep that sucker from backing off??
Thanks in advance.
Thanks in advance.
