That link has been posted here form time to time. It's not as cut and dried as stated. If you scroll down that link page about half way, you will find contradiction information. So let's look at the "pains taken in developing special flat-tappet camshaft wear tests:"
From the link: "Sequence IIIG evaluates cam and lifter wear using a V6 engine with a flat-tappet system, similar to those used in the 1980s."
From the actual test:
Sequence IIIG Measures lubricant thickening and piston deposits under high-temperature conditions and provides information about valve train wear.
"The engine then operates at 94 kW, 3600 rpm, and 150°C lubricant temperature for 100 hours, interrupted at 20-hour intervals for lubricant level checks."
The Starburst rated oils showed an average cam/lifter wear rate of less than sixty micrometers. That is the "standard."
So from the test cited in the link, you
can use modern API rated oils in your flat tappet Briggs and Stratton, it's just fine. You can even use it in your vintage, low power, car engine, as long as you keep the RPM below 3600 RPM, check the oil and add if necessary every 20 hours, and use stock valve springs.
But the Sequence IIIG test hardly dispels any "Myths" based on empirical data from the past 70 years of using low zinc oils and theie relationship between wiped cam shafts.
The number one thing you can do for an engine is to change the oil more often.
