Merry CHRISTmas. Hope Santa got y'all what you were wanting.
With the current very cold snap, 16 here this am, that's too cold here in SC. I will not be doing any work on mini's till it warms up some. Suppose too warm back up into the 50 and 60's in a few days.
My plans are too mount a 1" riser/jack plate and see if stock engines exhaust and breather will clear, so CVT can be used in a stock configuration. Going to get into stock engine some. Check valve lash, I do suggest doing this with any new engine. Going to move governor spring and adjust for max rpm of around 5000, I don't do the zip tie trick !
My plans are too put the WC223 from my CT200 on the MB. Going to put the stock engine on the CT and will let y'all know how it holds up. My WC223 is a torque beast. I've port matched, port and polished head, Stage 1 exhaust and breather. Going to put TAV, 60T sprocket on MB. I found a swingarm mounted chain tensioner, with the 60T and the amount of difference of chain tension happening during swing arm travel, I hope this takes care of it. It should of come with one already, any mini with a swingarm, normally could use one.
