Can someone please walk me through how to install a masters of motion centrifugal clutch. I dont understand why the two pieces slide right apart and there are no hex washers to hold it on to the crank shaft. Im dying over here. PLease help!!!
If it doesn't have set screws, then you have to use spacers and and a bolt in a tapped shaft.(PIA) I've never used MoM clutches, don't know if they have set screws. (Max Torque brand has set screws) The sprocket can face in or away from the engine, depending on your drive set up. Lots of videos on it. https://m.youtube.com/watch?v=rlGiNTl9tgg
