I take it nobody maintains their clutches...
. Well, I contacted MaxTorque and was told this:
"...take the sprocket out (sprocket/bushing assy.) and set it in a small can with some 30 weight oil. Let it sit in there for 24 hours. Heating up the oil will get it to penetrate further into the bushing. Get the oil hot but don't boil the oil. A crock pot with your can of oil in it is a great way of doing this. I also put in a cube of paraffin wax to seal in the oil when the wax melts after about 45 minutes then it is ready to take out and remount. Let it cool down so the wax seals in the oil. The cheaper the oil the better. A straight 30W petroleum oil with no additives is ideal. Stay away from Slick 50 or any oil that has Teflon or silicone in it because they will ruin a clutch."
...and also this:
We use a 2 pound coffee can to put in the crock pot and we save the oil with the wax in it. We use the same solution to do our chains. And after cooking them for 45 minutes we just hang them over the can of oil and let them drip off back in the can.
When you do the chain never clean it with gas or brake cleaner. Just use a high pressure air hose. Why? The brake cleaner or gas will dry out the chain because it can get into cracks that the oil cannot get into. You can use WD-40 to clean the chain then blow it off with the air hose.
Thought I'd post this just in case others are interested!:wink:
