Today i tested the compressor with and without sideload, it runs from the other 230v output about 5 seconds then the generators overload relay kicks it off.
Same thing with the other output but it runs just 2 or 3 seconds before the relay kicks off, plugged it straight to generator:shrug:
What if i would connect the two 230v outputs as one would it just kill the generator or what.
Have a 2000w generator that cant be used for nothing, it cant even run a small anglegrinder properly so i could test it with it.
A 2000w generator will run lots of stuff, a 1200w microwave, hairdryers, various ligths, refrigeator,and lots of household stuff. But thats about it.
Anything with a motor hooked to a load will draw 2 to 3 times the runing amps when swiched on and ramping up to normal runing speed.
If a motor has a full load amp (FLA) rating of 12 amps, it would pull anywhere from 25-40 amps when speeding up from a dead stop. This varies on the type of motor and applaction, but they all do it.
Hooking up two 230v outputs together will still put the same load on the generator, you wont gain anything there. There is also a chance that you could cross phases and make a nice smoke mechine out of your generator.
A few tips when sizing electical loads to power sources.
Your total load in watts should not be more than 80% of your power sources normal runing capsity.
Some things do not give the wattage draw, only volts and amps. So dang, now what?
Voltage times amps = watts
Heres a example for a random piece of equipment that runs on 120v and pulls 11amps(my grinder). 120v X 11amps = 1320watts.
Throw in a few 120 watt work ligths, a fan or two, and a radio. You can add all the wattages up and find out how big of a generator you need.
Grinder 1320watts
3, 120 watt work ligths;120 X 3= 360 watts
Fan; 120v X 2amp=240 watts
Small radio may pull 50 watts
If we add that all up we get 1970 watts. A 2000 watt generator would get it done tell you squezzed the trigger on that grinder, slaming the generator with the 2-3x's the normal runing current.
Anyways hoped this helps.
