Hey guys, I put the valves back in and have some new findings after two tests. The first one, I flipped the head upside down and put a puddle of water into the combustion chamber. I then waited a little bit and came back to see all the water gone and basically all of it dripping down the intake port. I was somewhat scratching my head on how that would work because the gasket was looped around the exhaust port, but whatever. Second test I filled the intake port of water and it immediately started dripping, then I filled the exhaust port of water and had a little bit of a slower drip. While the water was still in the exhaust port, I put my blow gun nozzle to where the valve meets the seal or the head and had decent air bubbles come up the port. So, my questions are:
1. Do I just get some valve grinding compound and attempt to make a new seal with the current valves?
2. Do I get new intake and exhaust valves, lap the new valves and hope it solves the compression problem?
3. Do I get a new head?
4. Do I get a new head and new valves?
I did take pictures, so if y'all would like to see them I can throw them up in my next post. Thanks
