So my 34mm mikuni flat-slide keeps dumping fuel out of the bottom drain tube. I use it along with a fuel pump on my 390 and it doesn't start dumping until i give it some throttle. It'll idle fine, no dumping, until i give it throttle, and then all it does is dump like crazy..
I'm not sure how to remove the float needle because it is clipped in, and under the float lever which seems irremovable. i'd like to try cleaning it out because it would seem to me that its just a dirty seat. only three possible causes of bowl overflow.. bad needle valve, bad float adjustment(not sure how to adjust) or broken floats, but they are fine..
anyone have a manual for this carb?
