Hey,
I finally got my modified predator 212 running and onto my Carter Brothers Go Kart. Once I was finally able to take it for a spin (which was fun as s%*t) I noticed oil seeping out of the pulse pump which is mounted on top of my top plate. My pulse is coming from the hole where the governor used to be (I drilled it, tapped it and put a pipe barb in there) and I have a billet valve cover which is piped into a vented catch can for some pressure/compression relief. So, my question to you all is this: how do I resolve this oil coming out of my pulse pump and also have I ruined my pulse pump? I will share that the motor still runs fine as I have taken it on a few rides with no other issues except for the oil out of the pulse pump. Thank you all in advance for your time and assistance. I really appreciate you all for all of the insight that I have obtained from these here forums.
