I have welded up a lot of deck gates, truck racks etc. Always drill a small hole in the lowest part for moisture to drip out. Seen several metal handrails that didn't have them that formed water inside, froze and swelled up like a balloon to the point of splitting. I do live in Arizona but it is...
Hey,
I finally got my modified predator 212 running and onto my Carter Brothers Go Kart. Once I was finally able to take it for a spin (which was fun as s%*t) I noticed oil seeping out of the pulse pump which is mounted on top of my top plate. My pulse is coming from the hole where the...
If I delete and cap off the primer bulb nipple on the carb body, will I have to enlarge the tiny vent hole that's drilled in the side of the carbs main body?
What symptoms would this cause if I were to leave the tiny vent hole unaltered if the primer line nipple was capped off?
I...
Hey folks ,
Just want to know how Many and where you put your vent on the engine to take off some pressure
I get my pressure for the pump in the crankcase ( front) and i only have a vent to take pressure off in the valve cover. Is it enough??
Did you think if i have to much presssure in the...
Good Morning OldMiniBikes,
I am looking for some help. I recently acquired a go kart for next to nothing. It had a 5.5hp Tecumseh power sport on there. It was not quite fast enough and I always wanted to see what the predator hype was about. I pulled the tec and installed the 212. Runs great. Unless...
Greetings! Joined awhile back but p/w stopped working. When I applied for a new one and entered my email addy it just states "this email is already signed up". Long story short I had to take out a yahoo one. Just finished restoring a Stellar Black Beauty and was hoping to post a few pics of it...
I have a Predator 212cc California version motor with a OldMiniBikes Stage 1 performance kit, what type of aftermarket gas type vent filter is recommended?
I bought an airfilter kit for my new Coleman 196cc minibike.. where does the crankcase vent tube go when you install the new filter kit??
I don't want to leave it open and dangling to suck in dust..
Suggestions on a CHEAP filter (aka mini KN knockoff maybe) for it maybe??
Im sure some of you guys have had similar situations.
I have been dating this girl for about 15 months. She is great, her daughter is great and I love them to death.
Her ex is the problem. He is a piece of garbage. 3 months ago he stopped paying his child support. They took his driver...
I am redonig a Go-Devil.The only thing missing is the brass screw vent that screws into the gas cap. Anyone know where a guy can find one or something simmilar? I know some of you guys have gotten inventive. Give me some pictures or what you did. Right now I will use a ss bolt with an O ring...
where can i find a 1/8" pitcock and 1/8" breather vent ?
I've ordered a gas tank that needs both a 1/8" threaded peacock and a 1/8" threaded vent plug and have been looking online everywhere and can't find any. Maybe I'm looking at the wrong places, but even local stores around me don't have...
Well I'm pulling of the air filter and exhaust off of the predator and getting ready to put in the carb and air filter and header I just ordered from arc. I get all this off and now I'm wondering what to do with the gray tube.
I put a bolt in the end that would normally hook up to the stock...
I believe that this may only apply to the California HF clones with the unvented gas tank caps and extra emissions junk...
I know the purpose of the breather/vent tube and not to plug it if disconecting it for any air filter mods. My question is this: I am assuming that there is an inline...
At what level of engine build is additional case venting beneficial/ required? Is it just after governor removal or is it related to a specific RPM? My engine is nothing fancy but I do have a side cover leak.
I had some spare time today due to the rain. Here's something that
I did save a little money, and I like building things from stuff laying
around my shop. My homemade vent tube breather filter.
Step 1 -
Find a party popper.
Step 2 -
Take it appart, DO NOT PULL THE STRING! It will...
Hey Guys, just got the 22 Mikuni on and while the bike is Idling or when I am riding fuel either dumps out or drips out or the tube that connects the bottom of the float bowl. Can anyone tell me what is causing this and how to fix the problem. Thanks again.:thumbsup:
