No it doesn't bolt right on. You will have to drill new holes. I use the mounting plate because you can line your chain really easy, but if you don't use plate and just dril the holes using 212 as templet you have to make sure your chain lines up as straight as possible. And don't forget about your tensioner when doing so.
