Should be able to go to your local bearing supply and walk in with your dimensions ... They will find the right OD bearing to work with your 3/4 axle ... I see you have been looking for rims to work with your axle size ... What's in the hub doesn't matter ... You can find the correct bearings easily ... :thumbsup:
This should have a sleeve through both bearings to reduce them to 1/2. If the sleeve is removed, a 5/8 axle can be used. At least that's how mine are setup.
