Ethanol free gas. Good octane. And I keep getting pinging or piston slap or whatever on my little Briggs 8b flathead (2-1/3hp?)...
Was thinking it could be the missing 2" blower plate extension I removed from the shroud top, at the head. (I know I said all this in older post, but I'm bored).
It also occurs to me now that the 3-legged coil on this one is a lil' chopped, in that I rebuilt it with a Tecumseh electrical assembly. (This required removal of the windings and shaving approx 3/16" of stacked plate material from along the sides of the armature's middle leg. (Anybody see Roadking805 do this on YouTube?) Just fit the new Tec electrode assembly onto the modded middle leg with some Bondo. Well, it worked, but I wonder now if that procedure changed the timing – which seems likely now that I'm thinking about it. Or would it not, cuz there's still the points?
As an aside, I removed a good amount of timing by shaving about 1/8 of a key width and not only did that hurt torque, but the pre-igniting persisted!
So, well, blah blah blah later, I had the flywheel off to install a stock key again and I just thought I'd post some closeups of my points..
