I have a 1980 Ski-Doo Everest L/C Electro 464 snowmobile. Last season, I...well...the oil injection pump...toasted the crank pin bearing on the magneto side connecting rod. Lets play a little game of spot the difference:
Now that first picture, the PTO side, seemed okay, right? I know this engine was rebuilt before because the connecting rods were facing the wrong way! Both of them!!! The lubrication slot that you looked through should be facing the other way according to the manual, since there is only one slot in each rod. I don't have to worry about this when I put it together because my new rods come with two slots, one on each side. That still doesn't change the fact that I must still take apart the good side because of that slot.
The first question to you is: "How do I press that crank pin out of the outer web?". Or more importantly: "Can that thin web take a 10 ton press?" and "What tool do I need to make?". This is the tool I have made so far. It doesn't work for :001_9898::
As for the tool I have to make, if the thin part of the webs can't take the force, there's three different depths in that web I would need to cover plus some raised numbers that would make a pressure point:
And...last question...for now? How in the hell am I gonna pull this one off?:
