So I started with this 1981 c70 I got last year put tons on miles on since then but trans started to jump out of gear and got harder and harder to start. while tearing down I found a bad cam bent valves and lots of metal in the trans.
So I was planing to rebuild the whole motor but because its the older 1981 and not the 1982 or newer i couldn't do stroker crank etc.
fast foward to now, I found a 1960 super cub so that is my project. And the c70 is now my gf's ride.
So the guy across the street comes over and says he has a mini chopper with a broke frame for 40 bucks so I went looked and it had a 50cc clone with everything I needed for the swap!.
So I brought it home pulled the motor out and the harness and it bolted right in the c70.
Now the only thing left is to finish wiring in the old harness to the new one and modify the old intake to take the new carb and thats it.
