If the wheel is aluminum a bit of heat can also be helpful. Pre-heat your oven to 250-275 degrees, and throw the whole wheel in for half an hour or so. The bearing should just about fall out. Be sure to first clean off as much of the old grease and solvent as you can, and take the tire off, too, so you don't stink up the house too much. I'm not familiar w/Foxes, but I've used this process a bunch of times to get bearings out of motorcycle engine cases, and it's always worked for me.
