Just purchased a 6.5 from HF and i added an AGK 2 stage straight header. Everything else is stock. I was thinking about getting a 22mm Mikuni carb and a UNI air filter. I also think i will need 18lb Springs and a billet rod and flywheel. I have a few questions:
Do I need an adapter to put the mikuni on a clone? If so, which one?
Do i really need the 22mm mikuni or will the stock carb perform just as well?
Which billet rod and flywheel do i get?
Do I need a Fuel pump?
If i use the stock carb, which jetting should i use and should i get a GX140 E-Tube?
Im trying to do this without spending a ton of money so if I can use the stock carb and rejet would it be fine?
If anyone can tell me their setup that works best that would be great. I am new to this engine modifying so any help would be appreciated. Thanks
