New carb! My bike is only running on choke
Kbg
New Member
So on one of my bikes I just put the stage one kit air filter jet ect. I haven't had time to mess w it but last time I started it it was only running on choke I just replaced the carb. I Do gotta figure this out next any ideas? I know about the clogged jets on a dity carb but it is brand new
cl350rr
If it will only run with the choke on, the mixture is too lean. Could be you need a larger jet, or it could mean you have an air leak in the intake track.
Kbg
New Member
Right so I did put a bigger jet then the one that comes in it along with w air filter I need to go over it this weekend I do appreciate
Kbg
New Member
Now that u say that I didn't replace that gasket wen i did the swap ur probly right . I have time this weekend so we'll see
