The Cox bikes are pretty cool, pretty spendy also …..
Probably around the same power as the last one I built.
That Bosch hub motor looks like good stuff, ''as with all Bosch''.
Edit:
I did just see that it's 1200w.
The one I just built,, is 48v./ 1800w.
For those who didn't know,,
''With a 48v. motor'',, you have to use a controller that will handle 48+v, & ''must'' use a 48v throttle.
Also,, if the motor is rated at say 1800w,, you have to use a controller that will ''at least'' handle that current, or you will probably ''smoke'' the controller.
Some controllers will do 36 ''or'' 48v. though,, like the 36v. BLDC conversion I did on the Wife's bike.
Using a 36/48v. controller on a 36v set up is a ''no brainer'',, because it is usually 12 fet, & is built pretty 'stout' to handle the extra voltage & current of a 48v set up,, if you want.
Our 36/48v controller doesn't even get warm, with the 36v. 1000w BLDC set up,, the controller is pretty much over kill.
