Been gone a while, sold the death trap and am now working on this.
I'm at the point of figureing out the drive line. The rear pully is 14", the largest pully I could put forward of it is 6" if needed. (see copper ring in pic) I plan on a jackshaft mount that uses the side of motor like this. Manco Go Kart Speed Reducer Kit Model 9981 | eBay
I see the charts that tell what size chain to use but nothing on belts. so, I could use that info.
Should I use a torque converter in front of the tire and solid chains on the motor?
Belt on both? 3/4" shaft, what sizes can I get away with? Campground use only.
I also will need a carb for the 5 hp motor.
This model uses the frame as an exhaust, see the crossmember forward the motor. I would like to use that but will require an over the motor type system. Any ideas?
I have to make the side pannels that cover it all up if I cant findsome .
