Shelby, to answer your question, the music is "Trampled Underfoot" by Led Zeppelin.
Qucifer, the build time was roughly 195 hours which includes time taken to run around and buy parts at stores. We were required to keep a work log of our projects, so I kept one as close and accurate as possible. The top speed I have not yet actually tested, but I must say it begs for more around 50mph or so. This might sound a bit "Rick-diculous" (SNL skit which I thought was funny) but I made a speed chart/graph with two input variables: the engine speed (rpm) and the torque converter ratio (all of the other parameters such as pulley size and tire height are constants). The top speed of the bike could actually be around 120mph at 4000 engine rpm. Now you all know the Comet CVT's are infinitely variable (within their min and max of the pulleys) so really the speed is undeterminable because a function cannot have two independent variables (unless the use of a second equation exists to form a system of equations, you know from your algebra days in high school). Since I only had one equation (Comet would not give me the "engineering" specs to the 94C/100D system to have a second equation) I had to treat the torque converter values as constants, so I chose the low ratio of 3.49:1 and a high ratio of 0.78:1 for the max and min and then chose a few ratios in between to help broaden the curve.
The 94C/100D has a much better low and high range than the 40 series we had. So when I'm driving the bike, it starts out easy due to the low low range of 3.49:1. However, around 50mph or so, the rear pulley hasn't even opened up yet and the engine pulley is only 1/3 of the way exposed. So this bike has a huge speed potential just like the speed chart/graph predicted. But there is no way in hell I am going to take the bike even up to 80mph since I do not trust the rear tire haha(even though it is 4ply). This way the Kohler can turn about 2000 rpm while the bike does 50mph.
I hope I haven't confused any of you, but I wanted you to know it is possible to determine your bike's speed analytically knowing the engine speed, tranny ratio, final drive ratio and tire height.
It seems I can now upload more pics, so I will finish up the bike build.
Enjoy.
Enjoy.
