Another small update.. I have pulled the head off the engine to see what length rod I need to order, it looks like I need the 20 thousands longer one. I will be ordering the rod, a cam, springs, retainers, gaskets, and other small parts soon!
I have been working on a "dashboard" recently. The goal is to be able to display engine rpms (by using a hall-effect sensor to pickup on the flywheel magnet), mph (by attaching a magnet to a wheel or disk brake assembly and then pickup on that with another hall-effect sensor). I want to have a little 4 digit segment display which I can use to show mph, rpms, the time, and maybe something else. I also have 8 RGB leds below the segment display which I will use as a tachometer (each dot representing 1k rpms) and also to indicate that the turn signals are on.
Tonight I'm going to try and code up auto-highbeams
More to come (and soon!).
