NOS Tecumseh shortblock
Hey all, I picked up several boxes of NOS Briggs and Tecumseh parts. I'll try to find out what will fit the minis and give everyone here first dibs at them. I cannot find any info on this shortblock. It is a replacement number 80143A which replaced the 80143. Everyone shows it to be discontinued so I cannot find a price. The tag number on the block is SBH-414B. This is a flywheel side bearing block, and is loaded with piston, rod, cam, valves, but no crankshaft. The bolts have not been removed so I assume this is how it was sold depending on fitment. The bearing, seal, and gaskets are still with it as well. I will take $125 shipped on this, hopefully someone can use it. Thanks, Bubba
Paypal accepted if the fees are covered.
Looks like an HS50 motor,I do believe the 4 and 5HP crankshafts are the same so either one will work in this motor. Can you show a pic of the ports where the carb and exhaust bolt on that engine? Thanks.
