Back when I was restoring a lot of bikes I sourced these hard to find "staked" nuts and OEM engine plate bolts to give the restorations that crowning touch. No lockwasher necessary with these, just a flat washer so you get that clean factory built look.
If you worked on enough original bikes you will recognize the 5/16" engine plate bolts with the cool head markings and hard red loctite goop on the threads . These were used on many early bikes, these came from a long defunct mini bike factory . The ones you are getting are NOS.
Included are 10 of each: 1/4-20, 5/16-18, 3/8-16 and 4 each 1/2"-13 staked nuts and a set of 4 OEM engine bolts and nuts.
There is one 1/2"-20 nut missing from the group photo..I touched it to the buffing wheel real quick to show this hardware will polish up like chrome with little effort.
Shazam!!...like the Hope Diamond
hmy:
Stop spoiling your restos with that junk generic box store hardware. :thumbdown:I did all the legwork for you here locating all these specialty fasteners.
You get the whole kitten-kaboodle, all 42 pieces for $17 shipped or 2 easy payments of $8.99 !
Order now, quantities are limited.
>>>> ( I can make up 3 of these kits and that's it, they're gone.)
