hello, my son has been bugging me about getting his gokart running. so heres what we got: a ohh50 tec, a very small streaker 2 seater, 4.10x3.50x5 stud tires, 11t clutch sprocket, 48t drive sprocket(one wheel). i had to junk the stock carb(POS). i put a carb on that came off his 3 wheeler, 1984 honda atc 125m(4 stroker). took it apart, let it soak in gunk carb cleaner for 24 hrs, ran a small wire thur every lil hole to make sure it was clear, the float floats, new gaskets and seals, new inline fuel filter, and install an aftermarket air filter. i had to remove the stock muffler, and repaced it w/ a 3/4"x10" pipe. now it starts first pull every time, idles great, pulls very hard at mid and high rpms, comes back down to idle fine, but has a BAD bog just off idle. i did notice while i had carb apart it has #96 main jet and #38 idle jet. the needle was set on the 3rd from top on the 125, i have moved the needle up and down, but idles and starts best on 3rd from top setting. it has 2 more up and 2 more down. idle mixture works best at 1.25-1.5 turns out. new plug showing black soot. hes happy w/ it, but has to keep feathering the throttle to get it to move w/o stalling. but after he gets it moving, look out:2guns: got nothing but tire spinning, dirt throwing, sideways hold on and drive. all replys welcome. by the way, GREAT FORUM. thx, rick:smile:
