Got this a couple of months ago, mainly for the 6hp Briggs engine. Was garage kept for some time. Solid rubber AG tires have flat spots in them. Got it out this evening. Pulled the plug and poured some oil down the cylinder. Topped off the oil in the crankcase and turned her over a few times. Checked for spark...had that. Put some fuel in it and put the plug back in. Pulled her over a few more times while it tried to start then the recoil broke. Took off the blower housing and re-wound that. Re-installed and it fired up. Smoke like crazy for about 5 minutes. You can see the oil that came out the head and the carb. The one carb gasket is leaking so I shut off the fuel and ran it dry.
