Hello again, the generator I talked about in my other post was working fine but this afternoon after it ran out of gasoline waited until the engine was cold poured fresh fuel started after first pull like always it ran for less than a minute and turned off slowly like it ran out of gas, it wasn't an immediate shut off like it does with the oil shut off, tried to started and nothing checked for spark and it has strong blue color spark, sprayed starting fluid nothing happened, removed the valve cover turned engine by hand valves work like it should, what I did notice was without the valve cover the engine turns like no sparkplug is on, I installed the valve cover again and it turns normal again, I think the piston rings are done, turned engine with a finger where the sparkplug goes felt a bit of vacuum but no compression, now I wish to install new piston rings and not sure wish one works with this Honda Clone, its a JD 6.5HP All Power Generator APG3002.......
Model: EF:9JDGS.1961GA EM196cc displacement
Thanks in advance TP
