I have searched and searched but have no idea who the maker is, any ideas?
Got this roller for $20. The Max-Torque clutch is good but the engine not (but I have a Honda GX160 for it). Tires, sprocket, etc. all good. Almost 100% certain the forks are not the original to the frame as the PO drilled another set of holes due to the smaller shaft/bolt size. The overall frame is OK, but it has several drilled holes and one 4-inch tube section was cut out? Welded all the extra drilled holes (forks and frame) and welded back the missing 4-inch tube, now the frame is more solid and in much better shape but still have a lot more to do.
Thanks.
Thanks.
