Hey all, Hemi all done and back in the bike. ARC billet rod (stock length),billet flywheel, 22 pound springs, mod 2 cam, 10 thous. metal head gasket, governor completely removed, valve lash set @ 3 thous. Also has the OldMiniBikes 140 emulsion tube,36 jet, high flow air filter, header with muffler, stock carb. Added a blow by fitting where the governor rod was and it ties into the breather tube of the head and into a breather filter.
Sounds pure "EVOL", and runs like an assaulted ape,but idle quality is pretty sad. Feels like it's not getting enough gas at idle, I had to crank up the idle speed to keep it running. But that in turn has the clutch trying to engage, so she doesn't want to coast at idle, keeps on pulling. Odd thing I did notice was that it runs faster when the choke is on, again like there's not enough gas flowing at idle. I did pull the idle jet and make sure it was open, and sprayed around the carb/intake to check for a vacuum leak.
Maybe pull the carb off and try and clean out the idle circuit? Any other things I might be missing?
