This condition is common on my Black Widows. I have found that it occurs when I run it a little rich. The Dellorto carb on the Black Widow really brings the engine to life, especially when you really pour the fuel to it. The drawback is popping that occurs when you back off the throttle quickly due to the unused fuel still left in the exhaust. The same thing was normal with the old flathead Briggs engines in kart racing. You would always hear the popping/backfire when you suddenly let off the throttle and the butterfly or slide was closed for a split second. I feel sure that your experiencing this due to the increased fuel flow from re-jetting. Best way to test... try running it hard and, instead of getting off the throttle quickly, roll off the throttle slowly. If you don't get the backfire, you're probably just a little too rich and you can fix this by dropping down a size or two on the jetting. But, if you're not worried about pissing off a neighbor or two, it's not going to hurt your engine.
