powerdyne project roller
Think its a "Galaxy" this is the steel 6" wheel version with the drum brake. it had some homemade skid plates riveted on so I took them off and welded up the holes as well as 2 that were probably for some bolt on pegs, and cut a added on tab off as well. Looks like the original pegs were mid mounted typical welded on style, I like to weld on forward pegs on these like a lil indian. front forks were straightened up in the press and vice, someone before me dinged them up pretty good trying to straiten them unfortunately making the more S shaped than anything. I worked on them today in the press and got them pretty straight but they will need some bodywork done.
frame is not rusty or pitted, one wheel half does show some rust holes, what is seen is after media blasting the area so it wont open up more than what is seen in the pic. other halves are clean. Bike is as you can see disassembled, all original wheel hardware is there and usable, 4 new bearings for the wheel hubs included as well as the axles.
$160 shipped lower 48 only no PO boxes
I forgot to mention there ARE tires/tubes as well there rear tire is a vintage square sided chen shin slick which is a good and front is a decent chen shin studded tread tire. I also did cut the footpeg bar off a Rupp roadster2 frame I just junked that makes for a perfect forward footpeg bar with folding pegs for this frame that goes with it as well.
