Y Yukoncornelius New Member Jun 20, 2020 #1 Jun 20, 2020 #1 Do you need to remove the PTO key when mounting the clutch?
OND Jun 20, 2020 #2 Jun 20, 2020 #2 If your clutch has the key already built in it then take your key out of the crank .
Y Yukoncornelius New Member Jun 20, 2020 #3 Jun 20, 2020 #3 What size washer should I use? One that fits inside or one on the outside of the clutch?
Kmanator Jun 20, 2020 #4 Jun 20, 2020 #4 Yukoncornelius said: What size washer should I use? One that fits inside or one on the outside of the clutch? Click to expand... .750 or 3/4..Tractor Supply sells them in 2 packs as bushing shims. https://www.tractorsupply.com/tsc/p...erjam&utm_medium=affiliate&clickId=3165616860
