I've been running a stock internals Predator Hemi for about a year now. It's has the usual jet/e-tube/flywheel key/air filter/header stage-1 kit. I am impressed with the power this thing makes but have a serious engine building jones. Reading this forum does not help. :smile: To get my fix, I purchased another new Predator Hemi and a bunch of go-fast goodies. Here's the list:
Arc flywheel
Arc con-rod +0.020" (stock rod piston was 0.025" in the hole)
Black Mamba Jr. cam
26lb valve springs
SS valves/automotive style locks and keepers
Head/side cover stud kits
Prior to receiving the cam along with the included cam card, I had intended to have the head milled 0.035" which would reduce the combustion chamber volume to ~18cc. Along with a 0.027" MLS head gasket the static compression ratio should be 11:1. Now that I have the cam specs I plugged in the intake valve closing event for the BM Jr. (39 degrees ABDC) which results in a 10.2:1 dynamic compression ratio. I estimate cranking cylinder pressure to be >200 psi. This does not seem pump gas friendly to me. I was hoping to run 92 octane pump gas in this thing.
So my question is what static compression ratio should I be shooting for with this cam in order to keep the engine happy on pump premium?
-Ray
Arc flywheel
Black Mamba Jr. cam
26lb valve springs
-Ray
