I am a 15 year old new to minibikes, and I just bought a new predator 212cc engine. I took apart the governor and removed the low oil sensor, and plugged up the two holes. I put back all of the parts, as well as made a throttle connector to the carburetor with a coat hanger that seems like it works fine (it closes and opens butterfly valve completely). I attempted to start it, and it sounds like just the piston is moving, but nothing is firing. I checked and the spark plug had spark, and the carburetor has fuel. Is there anyway that the low oil sensor could be affecting the engine start switch? The wire that I clipped to remove the sensor looks like it was attached to a solenoid that also connects to the on off switch. Any ideas for trouble shooting? As I am just learning the basics about engines and how they work.
Thanks for any advice,
Jake
Jake
