hello oldminibikes.com forum members,
I have a problem with a Bjaj Motorsports DB30 97 cc 4 cycle engine tha recently won't turn over when rope starting; have been running the motor staionary while doing a little PTO machining( with a double-cut Bastard file on the crank end machined to 625 inch for better clutch assortment!),but when
after letting the engine sit overnight then trying to pull-start the Lil' engine it froze-up!!??!!
I took out the top-mounted gas tank,spark plug was caked with carbon deposits(as well as, what I could see in the top cylinder!!);I can rock the crank a little more than 90 degrees either direction but then the crank freezes up!?!
I was wondering if I should get rid of this engine(and replace with HF clone
mentioned in this forum),or find a rebuild kit-if this is possble-to repair it???
Seems like the bottom-end may have let go(only have run it stationary,and only at idle while grinding the PTO!!),and therefore this engine is toast???:doah:
Thanks in advance for any replies!
