What do you all do to restore an aluminum bore that is tapered or scored too bad to use.
My first thought would be to install a cast iron liner as I have literally done hundreds on motorcycle and ATV cylinders that I can bore all the way through but the typical Briggs and Tecumseh would require that I mount the block upside down and bore going up. I can do that on my boring bar but don't have a reliable way to center the bore and insure that it is on the original centerline since I have found that the top of the block is not always perpendicular to the centerline of the bore.
Any ideas?
Bill
Any ideas?
Bill
