these can be a pain. i know because both of the engines on my 2 running minibikes had this problem when i got them if your able to, try pouring oil down the exhaust port and in the "valve spring room" because it might be the lifter stuck and not the valve itself. then take a rubber mallet and tap the top of the valve and see if it goes back down, but make sure that the engine cam is in the position that it isn't against the valve first. then after it frees up more just keep working it back and forth..
