My Skat kitty rear chain is too loose. Is there anyone out there who knows how to tension it?
I've read that the shaft bearing the two gears can be adjusted somehow, but I cant figure it out.
Put your sprockets back on. Go in from the other side and loosen the bolt with a 1/2" head. Carefully Turn the shaft with the nut that holds the sprocket on. Should rotate but don't force anything.
