Skat Kitty Tecumseh H25 flywheel and lighting coil
do you have a side shot or better angle showing the fins :shrug:hard to tell just how much is missing off what looks like 3/4's of them. Also the part number.
thanks
That should work on any HS points motor too.
Thats actually impossible, as it COULD work on SOME HS engines.. I have never seen an HS with the 5/8 to 1/2 inch bore, the smallest taper.. like the H25 and H35 round tops used...
It's not to say it's not a larger taper than standard.. Some of the newer H35's have the 3/4 to 5/8 taper... So if it mated with one of those cranks, it would work on SOME!!!! HS engines....
. BUT the HS engines LITERALLY have like AT LEAST 4 different tapers to the flywheels..
assuming you get it to work on ONE HS engine, automatically means there are 3 engines it will not work on.. :mellow:
The coil pack will work on most any points tecumseh, but it would have had a rectifier panel with one way resistors originally.. You do not need them for lights, But it doesn't look rite in the HS motors..
