You'll be lucky if your carb has any adjustment screws on it...
The Federal EPA act of 1984 required small engine manufacturers to preset carbs for emissions levels, and most aren't adjustable by the owner now...
Most of us have at least one that runs too rich and fouls the plug...
One of my solutions is to change the air filter to a less-restrictive type...this lets in more air to mix with the slightly excessive amount of fuel you're already getting...
On an engine that is tuned well, switching the air filter and changing out the exhaust for a less-restrictive 'header' type also requires rejetting the carb to allow for more fuel to pass through the (now) free-flowing intake/exhaust path...
On a poorly tuned engine, the excess fuel sent through the intake by an overly rich carb setting isn't able to burn completely, leaving an unburned residue all over the combustion chamber, valves and spark plug...
Decreasing the restrictions in the intake and exhaust pathways allows for more complete combustion of the fuel, increasing performance, and decreasing unburned, fouling deposits...
In other words, take advantage of an overly-rich, non-adjustable carb by putting on a free-flowing air filter and a header exhaust...
The performance of the engine will increase noticeably because it is now able to completely burn that extra fuel the carb is letting through the intake...
