I'm building a Bonanza BA1200 with a stock rebuilt 1969 5-horse Briggs flat head minus the governor for cruising the pits at the drag races. I'm a good sized (old) kid at 6'-3" and 290 lbs. I'm planning on using a 12 tooth clutch and the Bonanza has already got a 60 tooth sprocket at the wheel. What should I use for jack shaft gears? I want the Bonanza to have good street manors. I don't need big top speed and I have no need to lift the front wheel.
