I try to keep things simple in my life. There are times that Stainless-steel has to be used. But what stainless to use?
I use a magnet and see if the hardware is pulled into it. If it is NOT pulled in, it is true stainless-steel and for most applications it is too soft to hold a lot of torque/force. I would not use it on a jack-shaft or mounting bolts for brake drums or chain tensioner device.
If the magnet does pull it in, it has a high iron content and is much higher shear strength and would work well in high stress areas. These bolts/fasteners will over time rust a little, but are better in the long run over carbon steel or Chrome-validium fasteners.
After spending 18 years at sea, I can tell you what really is stainless or not, and what will hold a load for a long time,or not.:thumbsup:
Its the Nickel that makes a good stainless.
The higher the nickle content the tougher the steel.
Infact remove the chrome and add the nickel and steel becomes armour plate.
Not harder but tougher and harder to penetrate.
As I said before the cheaper nickel free alloys are the shitty ones.
A few years back when nickel went over 20 bucks a pound ( ( 10 fold increase in 8 years ) the Chinese started to use a lot of real y low end stainless substitute products.
These have not lasted well because they are brittle and not as corosion resistent.
Super alloys like MONEL ( looks like gold and never tarnishes ) or INCONEL ( the high temperature stainless we developed for the first jet engine and turbo chargers durring WWII ) all have high nickel concentrations.
Some of the super stainless steels contain no iron at all.
For you Rob, you shoudl be looking fo rthe free machining stainless steels that have a touch of sulpher added to the mix.
This allows for faster easier machining ( usualy an S designiation in the name code ).
I read in the news about a clock made someplace in the USA.
It was wound up and is suposed to run counting th days for the next 1000 years.
Its gears are a Monel Alloy that is the exact same ratio as the copper to nickel in the ore from Creighton mine.
I don't know if they discovered that by fluke or experiementation but it used to be a marketing gimic.
In contrast to the allow they make from it take a chunk of that ore and get it wet and a chemical reaction starts with the air and it starts to heat.
Get enough of it in a pile self heating and it will burn.
I figuere there is around 3 or 4 billion dollars worth of the stuff burning between 5800 and 3800 level that can't be recoverd.
http://www.ebay.ca/itm/1961-NS-Sava...724?pt=LH_DefaultDomain_0&hash=item23232c472c
