Anyone know if the stock cam specs for the small frame engines are listed/shown anywhere online or anything like that. Wanting to compare the H30-35 to the HS40/50 to see if they are the same duration and lift from the comfort of my office chair :laugh:
Im degreeing out a h35 now. I have a hs40 block, crank, rod, no piston. maybe I could get tdc off the top of the rod. the 35 should be done by the weekend
I have 2 side-poppers and 2 HS50s, and was wondering the same.
I'll attach a degree wheel and indicator to widen the sample pool.
Cancelling the lash factor by pulling valves and going directly to lifter?
thanks guys, not a real big deal to go out of your way or anything though, was just curious. I'm rebuilding an HS this week so I can break out the stuff and compare as well, just was not sure if that type of info was in print or not.
