make sure the output shaft is at least 2 1/4 long modern clutches will not fit on a shaft that is less than 2 inches. many small engines have smaller shafts and the clutch is to wide. you must have some shaft showing after clutch is on in case it starts to slip off. others can weigh in but i do think 2 1/4 is minimum for a clutch.
