$1200.00
Located in Mount Airy Maryland 21771 for local pickup. I will meet up with in reason.
For your consideration is a vintage all original survivor Montgomery Ward mini bike with the original 1975 Tecumseh ball bearing HS50 5hp engine and Comet torque converter. You can still see some factory cross hatching on the bore. The bike fires right up and runs excellent. I went through cleaned the engine up, new points, side cover gasket and seal. Cleaned the converter and added new chain. I also fixed the original brake band lining and changed the rear bearings and added the same but nicer vintage double headed indian Carlisle tire on the rear. This bike has A LOT of Torque and is a blast to ride. Would make a great bike for someone looking to have a good time on a reliable vintage mini bike! Please message me with any questions you may have.
Tecumseh HS50-67036A Seial 50340
Shorud is zinc plated to prevent rust on the inside thats why it is so clean. I was told Tecumseh did that for a short period of time in 74. This is a early 75.
Montgomery Ward - Model ZCQ-18735A
Serial - 37H-7571
YOUTUBE VIDEO OF THE BIKE RUNNING AND WALK AROUND -
Serial - 37H-7571
